| RE: Image upload test Graham
Instead of modifying the size of the image, try reducing the resolution. Then reduce the size. Also use a jpeg format as you can use a compression algorithm to reduce it even further. Paint shop pro or microsoft photodraw are reasonably good for this kind of work.
Best Regards
Robert
The Whistler!
__________________ Best Regards
Robert
My Son had a toy steering wheel which he used to spin furiously, making loads of go-faster noises, leaning into all the tight corners, perhaps running the government feels a bit like that. You make all the noises, but when you stop you haven't really gone anywhere. |
