Originally Posted by phil Hi Mike,
Where did you get the lower bracket from (screen to scuttle) for your centre stay? GD have only supplied me with the upper bracket (stay to screen).
Is it necessary to have the stay fixed to the scuttle? or can I make do with the centre stay fixed between the screen frame?...the screws that have been supplied are very small and would probably not be long enough to go through 2 brackets and have enough thread to fix to the screen.
many thanks
Phil |
Hi Phil
Got the complete lot from Brasscraft, personally I would go for the fitting that goes on the scuttle if you are using a hood, there is a hell of a build up of pressure inside which will tend to lift the frame of the top of the windscreen. if you are not fitting a hood, I suppose the stay between both frames will do.
