Thread: Holly woes.
Old 02-10-05, 08:18 PM
Mr Bling's Avatar
Mr Bling Mr Bling is offline
Re: Holly woes.
Gonzo
Similar thing happened to me with an Edlebrock 650 when the engine was warm - shortly after start up - switched her off for 5 mins and then she would not start so i pumped the throttle a couple of times - like you i could hear the petrol running like a tap through the carb, lifted the filter off and could see the petrol pouring down the barrels - it stopped after about 10 seconds. Not happened since - put it down to a stuck float caused by a bit of dirt which was probably flushed through.
You may find it was a one off, best advise i can give is strip the carb and ensure it is clear of dirt. The Holley is a good carb so i would not be in a hurry to swop it out without considering a strip and clean.
Good luck
J4N
383 Stroker power plus Anti-roll bar.....like being chained to a mad dog!! :-} There is no such thing as bravery.....only degrees of fear!!
