Old 07-10-05, 11:34 PM
Revets's Avatar
Revets Revets is offline
Re: On the Road............nearly
Originally Posted by robinj66
Congratulations ( I see from a later post that you have got it all sorted).
How did you change the way the speedo sensoris triggered? Mine is an ETB wheel attached to the propshaft.
I originally had the sensor mounted on a bracket off the diff picking up on the bolts heads on the CV joint on the driveshaft (does that make sense?). It's a set up that Westfield use except their bracket is must be more rigid and not prone to vibration. It worked OK at low speeds (up & down my road) but not at 70mph as tested at SVA.
I'm now doing the same as you with the ETB wheel on the propshaft and the sensor mounted on a bracket made using the Pilgrim template. No problem.
Steve
