Thread: Internal panels
  #14 (permalink)
Old 20-10-05, 07:40 PM
hfbradley01's Avatar
hfbradley01 hfbradley01 is offline
Re: Internal panels
Originally Posted by kevchard
Hi Howard
We will give you as much help as we can. Brother is getting on rather well with the woodwork.
At the moment the parcel shelf is soaking (trying to persuade it to go into the shape i want it to be).
Have you got anything in the way of inner wheel arches, or is it like ours with absolutely no inner front arches at all, and badly designed rear ones.
We went for pilgrim sumo door hinges as i thought they looked stronger than the dms/cobretti ones.
Keep us informed of the build and you are not alone.
Kev
The front and rear wheel arches sound like i've got the the same crap bits that you've got, fortunately it's not my problem to put this jigsaw together.
The door hinges I'm going to have remade in stainless steel but i'll give you a tip, weld plates between the two hinges on each door, this will ensure that the hinges are parrallel and will make opening the door much better.
Howard
Viper under construction - full steam ahead and hopefully on the road this year.
