Originally Posted by Clive Hi Nigel,
Did you fit any type of relector to the back of the bulbs? If you fabricate a back box out of sheet aluminium or anything else and line it with a reflective lining ie. silver foil, it should brighten things up.
Regards,
Clive. |
Hi Clive
There is not so much space to get reflection here with these lamps. The bulb is dip in the bulb holder, only a small part of the top is above the flange. But it is worth to try with some aluminum foil first.
Regards,
Cobra289
