| Re: Correct Electric Fuel pump? Steve,
If you hook up the Facet to your existing fuel lines on a temporary basis, you can disconnect at the carb and do a flow check into a fuel can.
It won't take into account any pressure losses in the carb but might give you a clue re. adequate line sizes.
