Originally Posted by snake_bitten hi Mike'
have you tried a virus scan? you could have a bug.
other than that, try plugging your cradle in another USB port or try your mates cradle on your PC that should eliminate the cradle as the problem.
one thought is that the connection on the cradle is loose due to useage, I had a similar problem with a phone cradle after 12 months of daily use.
good luck. |
Yes done all that, even bought a new usb sync cable, still doesn't work, starts syncing then cuts of.
