Originally Posted by PeteV Thanks Chris - that's exactly the sort of thing I was after !! BTW, where are those rubber mounts from ?
Pete. |
Dont take this wrongly - only trying to be helpful. As a suggestion if you can get hold of some of the softer mounts - they curve around the waste like the ones dax use, they are kinder in resisting the rocking of the engine due to torque off the drive train. Otherwise you are relying too much on the manifold and exhaust to stabilise your engine. Ever wonder why some manifold fail at their weld points.
Just trying to help you avoid possible, not probable issues.
Mike
