Thread: Tyre pressures
Old 11-01-06, 08:27 AM
427scr's Avatar
427scr 427scr is offline
Re: Tyre pressures
A simple solution to understeer...
When the front feels light, just stick your right foot in.
Assuming you have a real engine, all the understeer suddenly changes to oversteer, bang on some oppostite lock and bobs your uncle.
Failing that, I run 19psi all round and I don't have an understeer problem at normal road speeds. I have noticed at very low speeds (car parks etc) that the car dosn't want to go round corners and the front wheels skip sideways. However, my old Astra Sport used to do that and I now have an Alfa GT that does the same thing. My theory is that if the production boys have a similar problem, why worry too much.
