Old 18-01-06, 06:12 PM
mylesdw mylesdw is offline
Re: Front Shocks, Lower Mounting
Originally Posted by bitsilly
Russel, could you explain the length of the dampers issue a bit more? Are you saying the Ram advised set up is too high?
Thanks
Ed
This interests me too. Mine has a standard set-up and I would say it is too low. There is only about 4" under the oil cooler and it is quite easy to clout it on an uneven road. I was wondering about fitting some bump stops so that the suspension will bottom out before the body hits the ground.
Does anyone know what the design ride heights for that chassis are?
Myles D-W
