Old 25-03-06, 08:54 PM
craggle craggle is offline
Veteran polisher.
Re: Harness Eye Bolt Problem
I had to do the same thing.
I fitted the rear transmission tunnel cover then drilled a hole to line up with the threaded nut. Using a dremmel I ground down enough fibreglass to allow the eye bolt to rotate. You may need to use a couple of washers to get the orientation of the eye bolt correct.
I think the threads are mounted that low because of the height from the seat base. You need the belt to be pulling up rather than sideways when tensioned.
Polishes to date = 17
