| Re: air keeps returning in coolant v8 A few little questions.
What is the Engine? Rover?
Where are you venting? Obviously you will need to vent the highest pipe, and on mine i need to vent the heater lines as well.
not ideal solution but you might need to do some fiddling with it running so it removes all the air from the system.
Good luck
:thumb:
__________________ Dean. Lost. 1 portion of common sense! Somewhere between here and last week. If found please have it committed.
If things are meant to be simple, then I wont do it! Hence why I have a Viper |
