Old 10-03-03, 08:04 AM
kdavies3's Avatar
kdavies3 kdavies3 is offline
RE: side pipe repacking
Hi Clive, if your perforations were blocked then the exhaust gases would be unable to expand into the main tube into the packing, effectively turning your side pies into straight through pipes the diameter of the perforated tubes.
So in theory if you have cleared the holes then you should be quieter.
Kev Davies
South Wales~~ ~~ ~~
Kev Davies
South Wales
DAX, 383 Chevy Stroker,
