Old 06-07-06, 07:15 PM
JohnWoodman's Avatar
JohnWoodman JohnWoodman is offline
Re: Edelbrock performer threaded holes
My holley carb has a vac port for the brake servo so I was planning to use that one.
But on the subject of vac for the brake servo, is it ok to use a hole in the manifold as you are basically tapping into a fuel / air mixture for the vac?
Is this the reason brake servos have non return valves in them?
John
If you drive a Cobra you are going to get wet.
Dax Toj 350ci Chevy, Tremec TKO600, 5" Sidepipes
