| Re: Edelbrock performer threaded holes Quote: |
Originally Posted by JohnWoodman But on the subject of vac for the brake servo, is it ok to use a hole in the manifold as you are basically tapping into a fuel / air mixture for the vac? | It is quite OK to use that port for the servo; the flow is all from servo to manifold and not vice versa.
__________________ Cheers
Myles D-W |
