| Re: Getrag..Is it really up to the job?? Hi Warren
For what it's worth I found this article some time ago.
Item 4 refers to a spring which if broken gives a sloppy feel to the gearchange.
Might be worth a check before you part with the hard earned cash.
Andy.
P.S. If you search the forum you'll find mixed reports on the Getrag and the correct identifying numbers etc. Some units are not as strong as others?
I'm told that the XJS unit is the stronger one but identifying it correctly can be a problem. Mine, which I know came out of an XJS cos I took it out myself, has 225 1:3 and 262 followed by a few other numbers on two seperate parts of the casing? I know of one other cobra running a SB stroker with 400ftlb of torque without any problems. |
