| Prop shaft next Just had a look at measuring the props shaft length. First thing that strikes me is how very short it is going to be.
However I have a nice flat flange off the diff at one end , but at the tremec end a rubber bit with a metal washer behind it with about a 6mm or 8mm hole in it.
What do I measure up to here and does the back of the Tremec 500 sound right to you.
__________________ David Clifford
AK427, Tremec and Stroker. |
