Old 04-08-06, 09:05 AM
darren darren is offline
Fitting the body
I thought I had the body fitting all sorted, bonnet on and rear suspension cut outs etc. Then I read a post on here about grinding a strip off the sills about 10mm wide down the entire length to help with door fitting. Is this something that everyone has had to do 'cos I really don't want to bugger up the body by either cutting off a strip and finding that there's not enough sill left to bolt to the chassis or rivetting the front and back down only to have to drill the rivets out to remove the strip along the sill.
I would appreciate any advice, I can't afford to pull any more hair out.
Darren.
Hydraulic clutch fitted - thought it wasn't working - half day of head scratching and tinkering - one big shove - clutch went bang - working perfectly now - bl***y sticking clutch plates
