Old 05-08-06, 11:03 AM
kevchard's Avatar
kevchard kevchard is offline
Re: Fuel pump / filter prob
Thanks Martin
The fuel system was a self designed cut/shut.
THe fuel pump is from an XR4i which feeds into a large cylindrical thing (if it is a regulator, it is not adjustable), it then feeds into the original granada large fuel filter, then into the 8mm fuel rails. The are a couple of flying saucer shaped metal objects near the injectors (one in the feed and one in the return fuel lines). I was told these are valves of some sort.
Where can you suggest getting a shallowish swirl pot from, as all this will have to hang beneath the main tank. Is it poss to get a swirl tank with an internal pump?
Kevin
Kevin & Helen
DMS Venom Viper
Granada Cosworth 2.9V6 BOA
SVA passed Aug 07
