Old 10-08-06, 11:02 PM
Cobra289's Avatar
Cobra289 Cobra289 is offline
Re: Engine Build-Up, Step by Step
Hi Martyn,
Thanks.
The block smoothing was a part of the job to remove the paint.
I was there and some edges were so difficult to remove the paint so I did the all sharp corners.
It was easy to remove the all the bunch of metal, than just remove the old paint from the sharp corners.
I have a Hydraulic Roller lifters and that doesnt need too much oil like the normal flat tappets.
Even they dont need to have a brake-in period.
This engine will not a full race and just will produce 405 HP with lots of torque.
I dont think that is needed to go so dip in the valley also because I have a mild cam, when the combo is based in some radical cam that introduce a lot of friction at the flat tappets and the cam, in that case we should consider the soothing of the valley.
Best regards,
Cobra289
http://www.donostia.demon.nl
Cobra289 Gallery
