Thread: Breaking in cam
Old 20-08-06, 10:40 PM
wilf wilf is offline
Re: Breaking in cam
Ok - basics are:
1: Engine must start right up, no prolonged cranking on the starter, and go immediately to at least 1800rpm.
2: revs must be varied between 1500 and 2500 - 3500 for 20 minutes. Don't let the engine idle.
3: Avoid stopping and re-starting if at all possible.
4: This is a severe test of cooling systems - have large fan blowing into rad, keep a cold water hose ready to play over the rad if temps start to rise uncontrollably (so do this outside of the garage)
5: Because of the above, check, double check, and triple check ALL engine systems before you start. Have a fire extinguisher or two ready.
6: again because of 4 - ensure ignintion timing is set "good enough" for the engine to run, timing can be adjusted during the cam break in period if needed.
7: again because of 4 - prime the oil system by pulling the distributor and using a special tool in a leccy drill to turn the oil pump (NB - drill will need to run in reverse) before starting the engine.
And no, your questions do not bore me or us, but the search function is a very useful tool to at least help you ask the right questions.
NB - no cam break in required with roller followers. For very aggressive flat tappet cam profiles needing extreme valve spring strengths, replace the springs with light "break-in" ones before you break in the cam.
All in all, cam break in is a PITA, so if you are having your engine built for you, get the engine builder to do it, and also to dyno tune and check the egnine before you accept it.
