Originally Posted by kayjayd I meant under the dash. If you don't already have a pic on file then don't worry. How did you do it, just put a y-joint in the flexi pipe? |
Ken should have supplied you with a fibreglass collector box which mounts on the inside over the heater matrix, I drilled four suitably sized holes to fix the flexi-pipe in and routed 2 to the screen vents and 2 into the footwells.
