Old 26-09-06, 04:13 PM
Sidecarbod's Avatar
Re: Removing the hub flange thingy (Granada based MkIII)
Originally Posted by gareth08
Pete,
I assume you already have the caliper etc removed .
The actual hub itself is on splines on the driveshaft and should pull off once the above and big nut are removed.
They sometimes stick on the splines/seals/bearing so a little persuasion is often needed with a soft headed hammer to get them off.
HTH
Hi Gareth,
You assume right, I've taken the disk and caliper off. I was actually using a screw driver as a sort of wedge by tapping it between the flange and the housing that has the bearing in it. I guess I just need to "tap" it a bit harder!
Thanks for the quick response.
Pete.
