  #28 (permalink)
Old 03-10-06, 11:10 PM
steamyrotter's Avatar
steamyrotter steamyrotter is offline
Serial Complicator
Re: Spring poundage?
Deck
My body was too low.
Placed on the chassis with the steering rack parallel to the chassis (ie flat and level) the nose of the body was touching the ground..
I have cut the inner tub out and mounted that flat on the chassis.
I will tweek and glass in the body to how i need it when i get that far and maintain the indicators at the correct height. May purposely set the suspension a little high for SVA then reset to look / handle better.
Still need to finish the wiring and rebuild the engine before i get to that though.
Think it is the only way to get it right.
Kev where did you see the 500mm to headlights?
That seems a little excessive?? with 6" between indicators and headlight????
Dean.
