Originally Posted by digger782 Hi
I think you will find this box is a LT77 as fitted to TR8 and rover V8's
Graham:thumb: |
Yes Digger you are correct TR7/8 are all LT77 apart from the early model which were Dolomite cr-pp together with there axle.
I use the later box which is an R380 but nothing wrong with the LT77, which was also fitted on Rover SD1 and things like Sherpa vans etc.
One word of warning don't run it on Auto fluid / Power steering fluid, use a proper gear oil, hypoid 80/90 as if you do and give it some serious track day stuff it will break
!! Osgood.
