Old 05-10-06, 03:21 PM
tony tony is offline
Re: where to get vacuum hoses?
Originally Posted by mikey
Easiest place I know to get the valve is from Dax, its a neat little metal unit that incorporates an arrow on the body to indicate the correct fitting orientation. They are not cheap, but thats not Dax as they are not cheap anyway.
Make sure you get a hose marked as vacuum hose or keep the receipt for the SVA. I managed to get the marked stuff, but its not always easily available.
All the best
Mike
You can get a one way valve from the scrappy, paid 50p for mine from a 200 series Rover, most cars should have one in-line somewhere under the bonnet.
Just make sure you fit it the right way round as some of us have been known to make that mistake .
I used Samco servo hose without markings and had no problems with sva. probably depends where you go , I gave the centre a ring to check in advance it would be ok.:thumb:
Cobraless again for now. But new one on order.
