| Re: Valve Preload AGAIN....sorry! Purple Chris is quite right; the correct length pushrods are needed to get the correct rocker geometry. As also mentioned above, you only need to worry about that if you have taken a big slice off the head and/or the block or if you were running exotic stuff like a reduced base circle cam.
__________________ Cheers
Myles D-W |
