Thread: Clutch Problems
Old 08-10-06, 08:44 PM
Sidecarbod's Avatar
Re: Clutch Problems
Originally Posted by martsam
Hi All,
I changed the travel on the clutch and was able to engage the gears with the engine running. However I cannot sustain the pressure on the clutch as there is a leak at the master cylinder. I changed the internals and thought that would solve the problem but as soon as I pressed the pedal down again I got the leak which causes the loss in hydraulic pressure. The leak is via the pushrod rubber gaiter. What is causing this as the original seal and the new seal were brand new and also a good fit into the master cylinder barrel. Any ideas as to what I can do as I'm getting a bit fed-up of taking out the pedal box to try and fix problem?
Denis
Sorry to hear that your still having problems. I know that taking the pedal box out is a right pain in the arxe! I don't know what causing your master cylinder to leak but a trick that I learnt is to block off the outlet of the master cylinder (in my case the banjo bolt was tightened down on a large nut with a copper washer either side). This will allow you to apply pressure to the system via the clutch pedal so that you can be 100% sure that you've fixed the problem before you re-fit the pedal box.
Regards,
Pete.
