Hi
Here is an update incase someone else needs to do this or finds it interesting.......
Back in july I needed to tighten the 4 bolts holding the inner mounting bracket to the diff. It seemed to be an axle out job but I made a couple of tools and was able to do the job with the wishbone and spacers in place.
Carlos was very interested in the idea because it makes shimming the rear axle easier and he asked me for a few drawings that he could put on his wwwebsite....
http://www.donostia.demon.nl/index_files/alignment.htm
As suggested on this forum I released the shocks and radius arm to reduce the load on the pivot shaft to make it eaesier to drift out and back in.
If you make the tools do ensure that they are about 4 or 5 thou under 5/8 inch.
hope it makes sense
cheers
phil
