Old 23-11-06, 06:52 AM
bogster's Avatar
bogster bogster is offline
Re: Which rivnut tool
Hi Paul,
Why are you using rivnuts in the chassis for brake line clips? If you just drill and install the push fit clips this is more than sufficient and makes it easier to remove the brake lines during maintenance. I only used P clips on the brake lines were they come up the side of the inner wing in the engine bay.
for the fuel and brake line you only need to drill and tap with m4 or m6 and use P clips for these. This will be more than sufficient. No need for rivnuts.
Bogster
Live the Dream
