| Re: Range Rover engine 4.0 V8 ' 96 The 4.0 has the same displacement as the 3.9 but has stronger crank and cross bolted block amongst other things.
The high lift cam and manifold / carb will probably add something like 40hp to the stock output though this will depend on the condition of the motor as much as any mods which were carried out.
