| Re: More photo's Well...... it's progress and more importantly i've got control back which makes me feel so much better.
Martin....i'm in the process of getting the fuel tank out of the car, i've had to cut of the 2 outlets at the bottom of the tank and i'm going to have to shorten the fuel pipe neck at the top, I should be able to remove it then.
I'll get some plates welded over the holes at the bootom of the tank were the 2 outlets were.
I can clean the tank out more easily out of the car and test the fuel pump while it's out. I can also fit some new fuel hose to the tank while it's out. I'm also going to make some brackets to stop any side to side movement of the tank when it's back in situ.
Thanks for your comments guys.
__________________ Howard
Viper under construction - full steam ahead and hopefully on the road this year. |
