Originally Posted by steveatyork Think i might just be looking at a way out of priming the pump ;-( I asked V8 Developments who built the engine (About 500 mls on it now) and they reckoned it should be ok as long as the front cover hasnt been off?, surly the oil drained off and the filter off isnt really much different to a normal oil change? only the oil that wants to come out will the oil that doest will stay in , hopfully in the pump? it was the new oil hoses that worried me more, i tried to get some oil into them, but it proved a tw--.
ay ideas with the stat appreciated
cheers
Steve huntington rd  |
That's what would worry me...that fact that the cooler and hoses will take a few seconds to prime and if your system is like mine that means no oil pressure.
At the end of the day why take the risk, it will take your at most an hour to fabricate the rod and carry out the work, you can sleep easy knowing that your bearings are OK.
Regards,
Pete
