| Re: Hydraulic Clutch Problems If you were losing pressure (and hence hydraulic fluid) in the way you describe, then the fluid that had escaped past the seals would be showing up as a leak from either the master or slave cylider.
Is there fluid around the pushrod end of either of those?
