Thread: rv8 fuel pump
Old 04-12-06, 05:34 PM
TINKA TINKA is offline
Re: rv8 fuel pump
Originally Posted by cperry View Post
I have an RV8 in my Half built sumo. I was advised to fit a silver top facet pump. I think it was £65 or so, you can find them on Ebay. This should delivery 4-6 psi to the engine, but will be a little low on full throttle.
You can fit a red top facet pump that can deliver over 6 psi but you will need a regulator too, as too much pressure will flood the engine. It really depends on the trim of your engine and how your gonna drive the car. If you have a big carb, race cam and drive everywhere with your hair on fire then a red top pump with a regulator will be needed. Standard engine with leisurely drives through the countryside and a silver top should be OK.
Of course this is only my opinion and no responsibility can be taken for being wrong .
Or just fit a carter = correct pressure and supply so no leaning out of fuel on full throttle or pressure regulator required. :thumb: :thumb: :drive:
