Originally Posted by kev If you use the 3.5 heads on the 4.6 block you should use the tin gasket otherwise you'll lose 05:1 off your cr. Rover took about 20thou off the head to reduce the combustion chamber size to compensate for the thicker composite gasket.
Kev |
Yes I sand corrected Kev, same size chamber but not so deep
Osgood
