Thread: AJ6 Engine
Old 18-12-06, 06:24 PM
StrangeRoverV8 StrangeRoverV8 is offline
AJ6 Engine
Hi,
I've got a Jaguar AJ6 engine, which I would ideally like to supercharge. I might not get anywhere here, but I guessed you might be able to answer some questions for me, you lot must have a fair bit of experience with engines between you!
The engine I have is a 3.6 AJ6 engine, 91mm bore and 92mm stroke.
The engine that Jaguar supercharged, is the AJ16, which from what I can see, is the same as mine but with an alloy head. It's 91mm bore, and 102mm stroke, to make it a 4.0.
Theoretically, if I can get hold of conrods and pistons from a 4.0 block, and put them in mine, I have the 4.0 engine am I right?
Then I can use standard jaguar parts from the 1995 XJR to supercharge the engine, which are available cheapish from eBay and the like?
