Thread: AJ6 Engine
Old 18-12-06, 06:40 PM
Purple AK Purple AK is offline
Club Sec/Rep Liason
Re: AJ6 Engine
Originally Posted by StrangeRoverV8 View Post
Hi,
I've got a Jaguar AJ6 engine, which I would ideally like to supercharge. I might not get anywhere here, but I guessed you might be able to answer some questions for me, you lot must have a fair bit of experience with engines between you!
The engine I have is a 3.6 AJ6 engine, 91mm bore and 92mm stroke.
The engine that Jaguar supercharged, is the AJ16, which from what I can see, is the same as mine but with an alloy head. It's 91mm bore, and 102mm stroke, to make it a 4.0.
Theoretically, if I can get hold of conrods and pistons from a 4.0 block, and put them in mine, I have the 4.0 engine am I right?
Then I can use standard jaguar parts from the 1995 XJR to supercharge the engine, which are available cheapish from eBay and the like?
Hi ???? Welcome to the Forum :thumb:
Firstly I'm guessing to get the longer stroke in the AJ16 they use a longer stroke crank.
Secondly The supercharged AJ16 probably runs a lower compression ratio. Which is either achieved by a different piston/or a different combustion chamber volume.
So it may not be as simple as you think
Best bet is a PM to KevDavis3 on here He used to work in Jaguar engine development :thumb:
AK 427 351C T5wc
