Well, to be honest when I ordered my engine in the US, I trusted that the price/quality was ok and decided on a standard package: (
http://www.pro-formanceunlimited.com/). I'm not able to fully judge the specs of the engine, but are of course very interested in your comments.
Hereby the details I received when I ordered the engine, sorry if I wrote down less important/irrelevant details
- Chevy 350, 1979 block, bored and honed
- Cast iron precision ground crank assembled W/Tri Metal Clevite 77 Rod and main bearings
-Set of I-beam connecting rods W/ARP Rod Bolts
- Assembled with a set of hand filled perfomance rings
-A three piece true double roller timing set
- A crane performance camshart (hyrdaulic lifte)
- A set of high rev lifterss
- Set of Edelbrock Alu Performance Cylinder Heads With 2.02 Int And 1.60 Exh valves, Scew in studs and Guide planes
- A set of chrome Moly Push Rods
- Set of new performance long slot ocket Arm W/1.5 ratio
- Edelbrock Torker II 5001 Series intake manifold
- Edelbrock 600cfm Carburetor
- high performance HEI distributor
- HIgh Volume Oil pump
- Performance balancer
