Originally Posted by dave The 4 pot one has the brake pipe coming from the center of the caliper and the 3 pot pipe comes from the top. (The caliper has bulges where the piston housings are, there is a sort of "8" shape on the 4 pot ones on both sides. On the 3 pot the inside one looks different with just a single circular casting shape.
The only way forward is to get it swapped. |
Hi
Is it just the wishbones that are different for the two different sides? Are all the other components the same? Looking at Ward's I could buy second had recon wishbones fairly cheaply. I was going to replace the calipers and discs any way. Is that viable? It saves me a 5 hour round trip if it is!!!
Thanks for all the advice
Martin
