Old 01-01-07, 03:35 PM
Sidecarbod's Avatar
Re: ETB Speedo Sensor
Originally Posted by Marc View Post
Hello
Can someone tell me how to test the magnetic induction sensor from ETB. I can't get any signal. I have tried to change the gap between the sensor and the magnet but the gauge still says no pulses. How do you test the sensor?
There are two wires, one red and one black. Can I some how use a 12 Volt light bulb and turn the wheel by hand to see if the sensor gives a signal??????????????
Hi Marc,
You will not be able to use a bulb to test for a signal as the pulse generated is VERY small, You could put a decent digital meter across the sensor and measure its resistance but you need to know what the resistance of a good one is...I suppose it will tell you if its gone open or short ciruit. ETB have a web site where you can download a wiring diragram and if you phone them they are very helpful.
Hope that helps!
Regards,
Pete
