The swirl pot and pump I got cost £15 from a local breakers, it is a pain to fit as you need to cut the tank open as I mentioned but once fitted you cant hear the pump at all except for a 3 second burst when you first turn on the ignition and it primes and pressurises the system. But if Tony has the room your system would be easier to fit, just most of us are really tight for space.
