Originally Posted by jgfabs Thanks Mark.
i,m going to check as best as possible as i would prefer a single hoop.Hope yours is o.k. too!!
Akll the best
Jim |
jgfabs, mine has a double width roll hoop. The mounts are not in the boot, but in the wheel arches. The other mount you require for your single hoop will need to be welded to the chassis in an almost impossible to get at location unless you remove a section from the inner boot area and then glass it back. As for the hole in the rear deck. This can be repaired but as with mine (someone cut the body for the single hoop) with age and movement of the glass fiber the paint has cracked in a circle. It may not have been repaired that well, but it has cracked.
Good luck!:thumb:
Kiss £6-£7k goodbye for your engine change!
