| V8 Head Bolts Hi guy`s,
Nearly ready to bolt the heads back on after a full (ish) rebuild. I noted in the manual that it states using thread sealer / lubricant on the bolt threads.
I`ve got some sealer that I used with the front cover / water pump bolts, and I`ve got some assembly grease / lube.
What should I use?
Thanks
Bob
__________________ Oh go on, darling. Just a few more ££££££`s and it`ll be finished!!! |
