Thread: V8 Head Bolts
Old 12-01-07, 08:14 PM
Sidecarbod's Avatar
Re: V8 Head Bolts
Originally Posted by wilf leek View Post
Hold on a second.
On some engines, the cylinder head bolts go throught the block deck and into the water cooling spaces. Ford 289W comes to mind, not sure what others.
Anyway - in those cases, a thread sealant is needed to stop water from getting up the threads and rusting the bolts solid in the block. (or leaking out through those threads).
Hi Wilf,
I presume that as Bob (Oldcobber44) has put his question in the Rv8 section then he is talking about a Rover V8, in which case it is OK to use lube. Having said all that you still have a point.
Regards,
Pete
I refuse to engage in 'ball-bag bothering' with an unarmed opponent.
