| I always use the carb/intake type lift plate and never had a problem. Even when fifting Big Blocks with gearboxes attached.
You must however make sure that the correct threasded studs/bolts are used and are correctly tightened.
__________________ Pro Dax Builder Current builds:- Dax No.126---------Kirkham No. 2 DB REPLICAS  Low Volume manufacturer |
