Thread: PCV Setup
Old 11-02-07, 02:44 PM
Cobra289's Avatar
Cobra289 Cobra289 is offline
Well done! That is the right way.
Yes that is what I did in my injected engine, clean out the internals of one valve that will works as the breather and the other as the real PCV.
The PCV should be from the vacuum side and the breather just from the clean air side (No vacuum)
At the injected engine there is a pass through channel at the ‘throttle body’ that connects to the breather valve.
Doing this way you will have a clean engine and you will not get oil fumes at the area. I like that.
Regards,
Cobra289
http://www.donostia.demon.nl
Cobra289 Gallery
"Improvement"ť means that you recognize previous mistakes!
