| I'm pretty sure I drilled and tapped the head of the existing body mounting bolt and screwed the eye-bolt into that. As far as the other end of the bolt goes just space your spreader out slightly with some small diameter washers; it can't pull through then and the bush can still flex.
Hope that helps
__________________ Cheers
Myles D-W |
