Originally Posted by ceejayjay Sumo RV8 with cable clutch. Cable snapped last year . Had new one fitted and re routed witrh less bend etc. Been fine but supect its noe stretched a tad and too near the floor in operation. Question ? ( a mug!! ) Is the best place to do this at the pedal end. Its wrapped arounf an ovel cam shaped cable router that sits at the top of the pedal. How do take up the slack and get earlier movement? |
if the clutch pedal is based on Sierra or Granada there will be a ratchet at the top of the pedal above the pivot and this adjusts the clutch automatically I vaguely remember other posts on the forum debating different length Ford cables and different cam adjusters giving a different height to the clutch bite. perhaps the cable was ok last year but where the clutch has worn it has highlighted the cable being wrong length. they do not normally stretch as such
steve
